Stuck spark plug HELP!!
Here is the deal i was changing the spark plugs on a 06 CBR 600 RR and first 3 went great and on the last one i was putting it in and it went in at an angle and now its stuck i cant get it out, i can move the tip side to side but thats about it. Any ideas?
When it went in at an angle did you twist it on with a ratchet and socket???? if so chances are you cross threaded it. If that is the case you got a whole nother situation on your hands as far as trying to re-thread those threads.....if you did twist it down with a ratchet then your goin to have to take it out wit the ratchet......cross threading is no good......
