stripped spark plug hole
Old May 11, 2007 | 04:42 PM
118367s's Avatar
Default stripped spark plug hole
is there any way to get the spark plug to stay in without droping 700 to fix it and getting aluminum in the engine
Old May 11, 2007 | 11:29 PM
tank_900rr's Avatar
Default RE: stripped spark plug hole
The best thing to do at home requires some work that'll keep you busy for a min but it's possible. I'm not tellin you to do this...but if it were my bike, here's what I'd do. Pull the head off the engine, tap the threads with the same size tap; if the hole is way out of round I would use a heli-coil(not proven to hold compression) and thread lock, replace the head gasket, re-install the head and do a cylinder leak down test. I know this is not professional at all but beats the hell out of buying a new head. Good luck.
Old May 13, 2007 | 10:36 PM
AudiCBR's Avatar
that or find next plug size with same ceramic heat range and thread protrusion into head and go one size bigger
Old May 20, 2007 | 01:31 PM
fishfryer527's Avatar
That makes sense. You would still need to pull the head to machine the plug/head sealing surface or not? Right? or not?
ajreyno1994
Aug 31, 2021 07:55 PM
LMP1327
Jan 5, 2010 07:46 PM
Eds929RR
May 25, 2009 10:19 PM
KoukiFC3S
Aug 12, 2008 03:56 PM
118367s
May 11, 2007 10:42 PM
