Stripped screws
Old Nov 13, 2007 | 11:31 PM
Nauree's Avatar
Default Stripped screws
I completely stripped a screw round on my front brake reservoir when I was using my drill with a star bit unscrew it. =/ I then drilled a hole into the into the screw and filled it with bondo and put the drill bit in it to dry over night. I tryed undrilling it in the morning but the bondo didn't hold on to it too well. So im back to square one. How do I get stripped screws out?
Old Nov 14, 2007 | 12:21 AM
Simplyred's Avatar
Default RE: Stripped screws
You should be able to go to pretty much any autoparts store or even maybe a walmart and get whats called an "easy-out" which can be spelled about 10 different ways. It gives you a drill bit that cuts into the screw and then you can back it out, I've used them many times on cars and had good success with them.
Old Nov 14, 2007 | 08:04 AM
cbr6oo's Avatar
Get a drimmle tool ( or how ever its spelled) cut a line in it and get a flat head screw driver and back it out. I do it all the time on airplanes. make sure the line is pretty deep too.
Old Nov 14, 2007 | 09:49 AM
Tahoe SC's Avatar
The dremmel won't work unless you have a VERY small saw wheel. that screw is somewhat beneath the surrounding resevoir lid.
i ended up using a sharp blade to etch the line (groove) instead, then went with a gixxer mc instead.
Old Nov 14, 2007 | 09:54 AM
Nauree's Avatar
I'm have to get that easy out.
Old Nov 14, 2007 | 10:13 AM
Scrufdog's Avatar
EZ outs are good, or find a set of reverse drill bits. Either one should get it out.
iamhiding
Jul 2, 2014 04:49 PM
C Average
Sep 29, 2010 04:27 PM
murdocity
Aug 26, 2009 02:40 AM
danny600rr
Dec 14, 2006 08:06 PM
cbrcamel
Mar 9, 2006 02:33 AM
