stripped tank screws
Old Mar 7, 2006 | 03:13 PM
cbrcamel's Avatar
Default stripped tank screws
hello all....
i need some advice. taking off my tank, i noticed the two 12MM bolts that attach to the subframe were stripped as well as the threaded hole....
can i use the same screws ( i.e. "repair them") and the threaded hole... all that i've been finding is how to Tap-n-Die a "smooth" area...
thanks!
Old Mar 7, 2006 | 04:24 PM
Tahoe SC's Avatar
Default RE: stripped tank screws
get a tap and rethread them holes. you'll need different screws too. you can try to repair the holes using the same tap and it may work.
there is also a kit to repair busted thread in bolts. looks like a nut and you just thread it over the bolt.
Old Mar 9, 2006 | 02:33 AM
Calkidd's Avatar
The easiest thing to do is install a Heli Coil you can get from your local hardware store..
iamhiding
Jul 2, 2014 04:49 PM
bowflexmaverick
F4i - Wanted
Oct 30, 2010 08:00 PM
C Average
Sep 29, 2010 04:27 PM
murdocity
Aug 26, 2009 02:40 AM
Nauree
Nov 14, 2007 10:13 AM
