stripped bolt
Old Dec 14, 2006 | 05:28 PM
danny600rr's Avatar
Default stripped bolt
whatsup guys im probably posting in the wrong place, but i figured there more people in here and i might get a faster response.
ok so im starting to install my slip on and i stripped one of the bolts under the driver seat. anybody know the best way to get this out i believe its a 5mm allen bolt. thanks
Old Dec 14, 2006 | 05:36 PM
mannyrios's Avatar
Default RE: stripped bolt
Dude... that happened to me recently. I lost two nuts when I removed the bracket that goes from one end, enter the seat, to the other. I can't even see the damn nuts. I'm just going to replace them. If anyone could offer some suggestions, that would be great. If not, danny600rr... just replace it.
Old Dec 14, 2006 | 05:58 PM
Brandon77's Avatar
They make tools specially for that, attachments for a drill that will bite into the bolt itself and take it right out...go to your local hardware distributor for more info
________
HYSTERECTOMY FORUMS
CBR 600 F2's Avatar
buy an easy out it is rev. thread so as the enters the stripped head it pulls it out autozone or home depot should have one
Old Dec 14, 2006 | 06:00 PM
D2VW14_20's Avatar
If the bolt is still in there and you cant get it out, and its already ruined, I think you can do one of 2 things.
(1) Take a size or two larger than the 5mm and a hammer and hammer the allen key on there to where its almost stuck on there (or a flat head screw driver), and it will atleast get it lose.
(2) Take some needle nose plyers and grip it the best you cn around the head, or if it goes through the bottom, you can try to do it from there, either way.
Either way you will have to replace the bolt and you can get them from cycle gear or anything like that, and until you get one, you and use on from the lower fairing on the front, since there are about 10 on there between metal and plastic. Good luck
Old Dec 14, 2006 | 06:07 PM
ddvs's Avatar
Wait, you stripped the bolt under the driver seat? I thought there was only one seat on motorcycles(not including the cowl). P.S. post us a picture of what it looks like up close and i'm sure you will get the answer your looking for(if you havn't already). Also, there are companies that sell 'Full Fairing Screw kits' they have almost every bolt/screw/hexbolt/washer/crush washer/ that is on your bike... I had to buy one for the F4 because someone tried to ghetto rig it to make the fairings stay on. P.S.S. don't buy a used bike in cali
Old Dec 14, 2006 | 06:10 PM
D2VW14_20's Avatar
There are the drivers seat and the passenger on the rrs(some have cowns instead).
Old Dec 14, 2006 | 06:30 PM
rrasco's Avatar
pff, those things they sell for removing stripped screws suck ***. all they ever have done for me is strip the head even more than before. i always just end up drilling them out.
Old Dec 14, 2006 | 06:42 PM
danny600rr's Avatar
thanks for all trhe advice guys so how would i go about drillig it out ?
Old Dec 14, 2006 | 06:48 PM
D2VW14_20's Avatar
Just take a drill the size of the screw itself or a size smaller and just drill the center out.
