Starting issue
ok i got good fuel..good voltage at the injectors..power and ground...can turn it over while box is open and no fuel comes out of the injectors...but i can get it to come out of the rail...i cheched the angel sensor with another good one i have ok...trippel checked all the fuses still all ok...checked the kick stand switch ok...i have not torn down far enough to take a plug out but i did take cyl #1 coil conector off to see if i am getting voltage at the coil i do get voltage...is the only thing left the ecu?
I am having this exact same issue on a 2000 929. I have checked everything including spark plugs. The fuel is not getting from the fuel rail to the intake. I have ohm checked the injectors and they are good and voltage tested the positive feed wire and it is good. Only thing I can think is that the injectors are plugged up but hard to believe all 4 would have the same problem with no fuel at all flowing through.
ok i finally got to the plugs after droping the rad down some...pulled trhe plugs out and all four were carboned up... and after buying 4 new plugs from honda( they must make these thingsout ofgreygoose cause they are expensive ) and intalling them..i draind the tank....put some new fuel and to my supprise fires right up...every time...the last think i would of thought of....but i dont care...its running and i get to ride
