Starting issue...
Old Mar 21, 2010 | 01:33 PM
derrickvaw113's Avatar
Default Starting issue...
Ok so my bike wont start. After getting the carbs cleaned and the plugs changed, I realized there was no spark. I am about to start checking the wiring with a voltmeter, but I was wondering if it makes a difference to replace the R/R with a Yamaha R6 one? I've seen a few people on here with that as an added mod, just don't know how much that will help.
Old Mar 21, 2010 | 01:41 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
it's not going to "help" anymore than the stock or aftermarket ones... however the r6 ones are easy to come by and aren't notorious for failing like the honda ones.
Old Mar 21, 2010 | 02:49 PM
ok so I was able to get a spark to the plugs, so I took the fuel pump cover off and realized that the connections were charred.. is there a way to gravity feed fuel to the carbs to try and troubleshoot past the fuel pump?
Old Mar 21, 2010 | 03:21 PM
Is the fuel pump switch suppose to keep sparking when you're trying to start the bike? PLEASE HELP the weather is so nice and I'm stuck walking around...
Old Mar 21, 2010 | 04:06 PM
you can bypass the fuel filter and pump yes. it will run yes, but not all that well past idle in neutral.
Your pump will pump like a heart beat every few seconds even when you are starting it... if it doesn't pulse, then it's a no go. bad wiring, bad contacts or something in the pump.
georx
Jul 6, 2010 01:12 AM
lilpakastain239
May 29, 2009 07:38 PM
Tclipse989gst
Dec 15, 2007 07:16 PM
SlavDog
Dec 5, 2007 05:48 PM
cottlefish
Sep 18, 2006 04:22 AM
