Starter problem
Old Jan 28, 2009 | 03:26 PM
sicocivic's Avatar
Default Starter problem
I have a 929 when i press the start button in wont start and the display turns off for about a minute does anyone know what the problem is?
Old Jan 29, 2009 | 12:21 PM
justasquid's Avatar
You may have to be more specific of the issue.
when did it first start?
has the bike sat for time period?
Does the display come back on?
Does everything else work until you hit the starter button?
From your discription so far, it sounds like a weak battery or loose battery connection. I would check the connection first and make sure its secure.
Old Jan 29, 2009 | 07:51 PM
sicocivic's Avatar
it first started on a long ride when i shut it off at the gas station the battery is good every thing works untill i press the starter button and every thing comes back on in about 1 minute and i replaced the starer kill switch and if i push start it after the display comes back on it runs just fine
Old Jan 29, 2009 | 09:41 PM
justasquid's Avatar
I know you said the battery is good, but have you had it load tested? A lot of times, the battery will short internally. they will work fine under a slight load, but a high load like tryting to start it will make it fail.
If you havent, I would have the battery load tested. or, if you know of anyone with a similar battery, swap them out and try to start it and see what happens.
Theres also a possililty the starter or the starter relay is shorting out. But I would do the easiest first by checking the battery.
Old Jan 30, 2009 | 12:00 PM
Gville George's Avatar
sounds like a battery...
mine is have sorta similar issues, new battery is in the mail, I will let you know if that fixes it.
Shadow
Feb 20, 2014 11:50 PM
600$tunter
F2 Tech
Oct 9, 2011 12:00 AM
ranchome
May 31, 2011 01:47 AM
FLspeedracer
Feb 27, 2010 07:11 PM
qck2003
May 21, 2005 09:58 PM
