Sprocket and chain install question
When putting on a new chain, the wheel should be pushed all the way forward and the adjusters turned all the way in (with minor adjustment to get the correct slack). As the chain develops slack from stretching, you tighten the adjusters so it moves the wheel towards the end of the swingarm.
This is really simple if you think about it. The longer the chain, the further back your axle is in the swingarm. Right now, your chain is so long, that the axle is as far back in the swingarm as it can go. If you remove a link, it's going to move the axle forward in the swingarm about an inch. Then you'll be able to have more adjustment available to you.
Is the gearing of 15/48 stock for your bike ? If not, then you can't rely on the adjuter decals for determining where your axle should be. You just have to make a note of where it starts out when the chain is new and properly adjusted. As it wears, it will slowly move to the back over time. Once it's been adjusted about the amount you see between the NEW and REPLACE marks, then it's time to replace it again.
I have about 300miles on the new chain so far so I guess next weekend I'll pop it back off, remove a link and see how it goes. I bought a generic looking master link from my local shop. Hope it holds up!
