Fuel pump not working?? help
Old May 23, 2010 | 11:42 AM
rubenv's Avatar
Default Fuel pump not working?? help
Hey guys i rode my bike, an 06 cbr 600rr, last week and it rode fine. it stayed parked for a few days and now the fuel pump is not working. dont hear the buzzing sound when i turn key. i tried a different battery, and checked the fuses on the left side of bike all good. i also checked the 30amp one by the battery. my turn signals stay on and headlights dont work. does anyone have any suggestions? thanks
Old May 23, 2010 | 11:46 AM
rubenv's Avatar
also where are the fuel pump relays located?
Old May 23, 2010 | 02:58 PM
justasquid's Avatar
Im not sure where the fuel pump relays are on that bike, maybe under the seat, or on the left side behind the fairing. But, the BAS will control the fuel pump as well, then there is a fuel cut relay, and a fuel pump relay that could all be part of the problem.
The other thing that will control the fuel pump is the kill switch. I would cycle it a few times just to make sure its not sticking internally.
Old May 23, 2010 | 03:10 PM
Kuroshio's Avatar
i know where they are on the F4i. Tail section, left side of the subframe. Dunno if Honda played tricksie with the 600rr just to differentiate the two.
But relays rarely go bad. They're solid state so short of a electrical spike (which should be popping fuses first), I'd look elsewhere, prolly the BAS or kill switch as justasquid suggested. Also verify the headlights. You try the highbeam too?
Old May 24, 2010 | 03:51 PM
skoobydoobie's Avatar
Check your main headlight harness, common prob is the ground wire connector inside the harness doesn't make good contact, thus resulting in headlights not working and the BAS killing the fuel pump.
95frankenF3
Mar 20, 2014 12:05 AM
akiyama640
Mar 4, 2013 10:07 PM
95frankenF3
Apr 29, 2012 11:12 AM
miksane
Aug 16, 2010 02:18 PM
GQuinones84
Feb 6, 2009 02:03 AM
