speedometer stopped working.
Old Jun 3, 2013 | 01:30 PM
f2cbr7700's Avatar
Default speedometer stopped working.
so i was driving it the other day and looked down and it was sitting at 0 mph.
so i took the cable off turned the cable with a screw driver and it made the speedo bump a little bit so im guessing its somthing inside not the cable?
i put the cable back on and leave it for now and i go drive it and it makes a "clicking" noise every 5 feet of driving so it goes faster with speed. what the heck is this click click click noise while driving it?? did i put the cable back on wrong?
update: took the cable off and clicking was still present. must be somthing inside the speedometer
Old Jun 5, 2013 | 11:31 PM
Zachy72's Avatar
If the speedo spins when you manually turn the cable then it's more than likely that the gear inside the front hub has been destroyed due to lack of lubrication.
take off the front wheel and look inside, report back with what you find
Old Jun 6, 2013 | 01:34 PM
mtbr_mark's Avatar
x2 I had these same symptoms last summer. Replaced the broken gear and I was good to go.
jnmacd
Jun 17, 2009 10:54 PM
KLO
Nov 17, 2008 09:01 PM
KLO
Nov 16, 2008 01:51 PM
jardine
May 10, 2008 06:34 PM
Sprocket360
May 19, 2006 03:01 PM
