Speedometer stop working, any ideas?
Old 06-28-2006, 09:17 PM
Mn_93f2's Avatar
Default Speedometer stop working, any ideas?
I went for ride over to my brothers house and when I started out there was quite a bit of traffic so I did'nt notice my speedometer was'nt working. As I got out in the rural area I noticed that my speedometer was bouncing around from 35-40 mph even tho I was going 60-65 mph. Any one have any ideas? When I got home I took the speedometer cable off to look at it but it seemed fine. I also noticed when I got home that my odometer was off. My brother house is about 21 miles from my house and my odometer said I had only gone 9 miles. If anyone can help I would really appreciate it. Thank!
Dan
Old 06-28-2006, 09:24 PM
Default RE: Speedometer stop working, any ideas?
I had that exact same problem a month ago, it's the plastic socket that sits over the nut holding your front sprocket on. It's worn out... order a new one from your shop for about $7.
You just grab the old one with a pair of pliers and pull it out of the sprocket cover housing...
While I was at it, I also degreased everything under there (after removing the chain of course)
*foolish me assuming yours would be the same setup as my 1KF*
Old 06-28-2006, 10:15 PM
city worker's Avatar
I think yer talkin about a 93 F-2 ???? right ???, my speedo cable runs down to the front wheel, cable attaches to a speedo gear housing that in turn is attached to the hub via a little flat washer thing that has 2 legs that sits up against a wheel bearing that the gear housing is connected to. The only reason I know this is when I did a new tire I had to do bearings also, soooooooooo while I was waiting for parts I cleaned and relubed everything along with cleaning and relubing the speedo gear you have to pull the front wheel to get to the speedo housing its on the left side, pulls right off, and then you can pull the little plastic gear out and look at it. I hope that helps
Old 06-29-2006, 01:07 PM
Mn_93f2's Avatar
Yeah sorry its a 1993 f2. I thought it might have something to do with the gear housing/box. Any one know if I just buy a new speedometer cable if it comes with the gear box too?
icedmind
04-04-2014 01:21 PM
F3LUV
08-12-2011 09:22 PM
LaughingMan600F4i
11-28-2008 05:12 PM
mpm600rr
09-18-2008 12:10 PM
nab
04-12-2007 02:20 AM
Quick Reply: Speedometer stop working, any ideas?
