speedometer not registering
Old Mar 12, 2005 | 11:42 PM
KEITH_N_MONS900RR's Avatar
Default speedometer not registering
we have a 99 900rr with a temporamental speedometer. sometimes it works, sometimes it doesnt. has anyone else had problems with theirs, and did you fix or replace it? thanks
Old Mar 13, 2005 | 09:08 PM
MapJr's Avatar
Default RE: speedometer not registering
Had that problem with a bike I use to have...it may not be the speedometer but the cable going down to the front wheel. It could be worn out or stripped.
Old Jul 12, 2005 | 04:04 PM
Charlie's Avatar
I have a 2002 Honda CBR 600 f4i.
I have the same problem - sometimes it reads
the speed, sometimes it doesn't. How do you fix it?
Old Jul 16, 2005 | 05:26 PM
xraycatj's Avatar
mine did that when my battery was dying.....fixed when i got a new battery....(dead meaning it would not hold a charge)
Old Jul 16, 2005 | 08:33 PM
sirlimpzalot's Avatar
99 900RR have the speedo driven off the countershaft sprocket pick up sensor....check the wiring down there and make sure nothing is corroded..and it could be the battery as well, or a connection on the back of the guages
Old Aug 16, 2006 | 11:23 AM
bigjoe954rr's Avatar
I have 954 03 speedo works sometimes but not most. Dose any one lnow specifics on the speed sensor or wireing leding to speed sensor
Old Aug 16, 2006 | 10:50 PM
bikz's Avatar
what about if the light doesnt work is that just a bulb or do you need to replace the whole speedo?
Old Aug 17, 2006 | 06:01 PM
Bake13b's Avatar
if your speedo is not registering start with the cheap stuff and replace the cable. you can get a replacement for like 8-14$. Its an easy fix all you have to do is get behind the instrument cluster and take off the old speedo cable and install the new one. scale of one to ten diff 1!!!!!
2006 CBR 1000RR Silver
Targa smoked windscreen
hotbodies flush mounts
shougun frame sliders
pazzo brake and clutch levers
CW fender eliminator
flapper mod
RR grips
Old Aug 18, 2006 | 03:41 AM
What light it has a digital readout and i followed the wire it goes to engine block
Old Aug 18, 2006 | 08:55 AM
bikz's Avatar
ORIGINAL: bigjoe954rr
i have a 97
pommie
Jan 1, 2012 06:04 AM
NoBrains01
May 1, 2011 10:47 AM
Decah
Jan 30, 2009 11:00 PM
FireStourm
May 10, 2008 10:26 AM
dito
May 23, 2006 02:22 PM
