Smells of petrol
Old Oct 1, 2007 | 02:09 AM
cafrin100's Avatar
Default Smells of petrol
Hi
I own a CBR 600 FX (1999), reciently I have noticed a very strong smell of petrol in my garage when the bike is left over night, there is no sign of petrol on the floor. Whats the likely cause?
Thanks
Old Oct 1, 2007 | 07:29 AM
thomasintexas's Avatar
Default RE: Smells of petrol
dirty exhaust pipe...OR oil may have been spilled on your engine casing durring your last change and it heats up on the outside of the casing when you ride. this causes the smell or well....stank...
take off the fairings and pressure wash the engine casing, take off the exhaust system and spray that as well....then hit it with a hair dryer to clear out the pipe then run it to make sure its dry as a bone after you get it re-attached...
should help out with the "vintage stink"
Old Oct 1, 2007 | 06:02 PM
knightslugger's Avatar
OR
Your petcock has malfunctioned and is dumping gasoline into the carbs past a malfunctioning float valve, forcing gasoline out the jets and into the cylinder, past the rings and into the crank case.
it's not as uncommon as you think.
Old Oct 2, 2007 | 03:25 AM
cafrin100's Avatar
knightslugger, thats exactly what I though...is it a garage job then?
Cheers
Old Oct 2, 2007 | 07:45 AM
no, just verify that this is what's happening, replace the petcock, remove the carburetors, clean them out, and reset the float height as necessary.
cycle.tim
Sep 1, 2012 10:44 PM
volitan
Jun 4, 2010 08:54 AM
amarillo
Jan 28, 2008 09:07 AM
just4u2
Jul 7, 2007 03:07 PM
aeroworks
Feb 23, 2006 03:23 PM
