smaller rear spocket problem
Old Oct 25, 2008 | 01:25 AM
jroymcd's Avatar
Default smaller rear spocket problem
just got a 99 F4. chain seemed loose. adjusters are all the way out. original owner ran a 43 in the rear, 520 chain. low miles on the chain. take a link out its way too thight. If I leaveits way to loose and out of adjustment. anybody else run into this problem?
Old Oct 25, 2008 | 01:19 PM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: smaller rear spocket problem
Im pretty sure 16/45 is stock, down 2 in the rear thats just odd, thing must be a dog. If you take out one link and its too tight then changing rear sprocket wont help either, if you add one tooth that will be like taking out one link. You sure the chain is good and low miles? Maybe the seller lied to you? I guess if it were me i would get a new chain and sprockets, that way im sure i have good equipment, probably a gear change too if it could use some pep.
Old Oct 25, 2008 | 02:17 PM
jroymcd's Avatar
so I took a long nap and figured out what went wrong.
I removed two links and it was too much.
can I get away with running two master links ( Rivet Style ) until I can afford a new chain and sprockets? [/align]
Old Oct 25, 2008 | 02:41 PM
TK954RR's Avatar
Jan 2009 ROTM
Yea, you wont be the first one to have done that .
Old Oct 25, 2008 | 02:43 PM
jroymcd's Avatar
how do I know when I have mushroomed the rivet enough?
Old Oct 25, 2008 | 04:15 PM
TK954RR's Avatar
Jan 2009 ROTM
When the link wont come off, then a tad more. It should look like the rest. You dont want to go too much though, it will bind up the link. Sorry i dont have a great answer for ya, its just a by feel kinda thing for me.
OrangeCapri
May 28, 2012 11:38 PM
cbrjohn
Apr 21, 2011 10:56 AM
Zero1080
Sep 3, 2010 11:33 PM
silvr002001
Apr 11, 2008 01:21 PM
