Single sided swing arm convesion on CBR600 F1
Old Dec 20, 2009 | 03:05 PM
ethanch's Avatar
Default Single sided swing arm convesion on CBR600 F1
has anyone done or seen a link to the VFR single sided swing arm conversion for a 90 CBR600 F1? any help would be much appreciated.
Old Dec 20, 2009 | 07:49 PM
Michael S's Avatar
Found this. It looks pretty sweet.
Old Dec 20, 2009 | 08:42 PM
ethanch's Avatar
I've seen this done to a number of F2 F3 & F4's but has anyone seen a post or a how-to for an F1?
Old Dec 21, 2009 | 08:28 AM
Michael S's Avatar
As always, I'm sure there will be fabrication. I would just pick up the VFR swing arm they recommend for the F2/F3 and just experiment. Check some motorcycle junk yards. And please, if you dont feel confident with your welding or fabrication work have a professional do it. The swing arm is something you can't afford to have fail.
Old Jan 8, 2010 | 10:46 PM
John Cu's Avatar
Does this swingarm fit in a f4i or i better forget it??? Cause it looks awesome... It would be better if someone had a how to.....
Old Jan 9, 2010 | 08:51 AM
ethanch's Avatar
A guy named Christopher Manning did a sweet How-to-do a conversion with step-by-step pictures and parts drawings, but all was deleted from an older server on one of the forums when the server was replaced.
He is in the States on Holladay for a bit but will send pictures and the How-to to me or repost when he gets back home.
Old Jan 9, 2010 | 11:49 AM
John Cu's Avatar
That would be great my friend, please do it but i had another problem, where can i find a Vfr here in Mexico, damn...i dont know...
Old Jan 9, 2010 | 12:46 PM
ethanch's Avatar
Are you looking for the whole VFR or did you just want the rear end for the conversion? If you are just after the rear end, swing arm, shock, rear wheel and linkage, you can get them all on eBay. You NEED the 4th Generation, 94 - 97 swing arm, linkage, and shock for the F3 & F4 conversion, that is the ONLY one that will bolt right up. Any year VFR rear wheel 90 - 09 will work with that swing arm. I think you said you have an CBR600F4i, so you are going to have to ask around or check for yourself to see if the F4i swing arm and swing arm mounts on the frame are the same or interchangeable with the F4. Good luck, and if you do it take lots of pictures as you go, to post along the way.
Old Jan 10, 2010 | 10:10 AM
John Cu's Avatar
Ohh that's some excellent info bro, now i know exactly what i need, of course if do it i ll take a lot of pics and make a how to.
Thanks... And please send the how to of your friend...
Old Feb 28, 2010 | 02:12 PM
leo_black_label's Avatar
Hows it going with this??
any progress?
im starting a sssa conv on my f4-
id love to see how youre doing or any new info/how-to that youve found-
pm me if you have time?
yorkiejeff
F2 Tech
Aug 6, 2015 03:32 PM
Haymaker
Jun 19, 2013 09:15 AM
RojerLockless
May 4, 2011 02:15 PM
durty116
Jul 3, 2009 10:07 AM
JakesF2
Mar 28, 2008 07:47 PM
