89 F1 single sided swing arm?
Old Jun 18, 2013 | 08:03 AM
Haymaker's Avatar
Default 89 F1 single sided swing arm?
Hey guys I want to swap my 89 CBR 600 over to a single sided swing arm. I have looked on eBay and the like but I can't seem to find a fitted aftermarket arm for an f1. There are plenty of options for f3s and f4is so I was wondering if anyone here has swapped over a later model swing arm onto their f1? If so then I would imagine it would be possible to fit a single sided arm from a late model onto my bike.
Any ideas?
Old Jun 18, 2013 | 09:44 AM
CorruptFile's Avatar
June 2013 ROTM
IIRC the VFR sssa can be made to fit with some fabrication. Not an easy job, though.
Old Jun 18, 2013 | 12:32 PM
ben12178's Avatar
I put a 600 rr swinger in my 87 I had to narrow it and weld dogbone mounts in. To put a vfr in I'm guessing you would have to narrow the pivot and make a new shock mount because if I remember reading correctly the vfr uses an offset upper shock mount. I guess what I'm saying is are you good at cutting and welding
Old Jun 19, 2013 | 09:15 AM
Haymaker's Avatar
Hmm I did some research and it does looks like I will need to cut and weld you are correct. I worked as a machinist for a few years so precision cuts are no problem. I would only be unsure of rewelding the right way to keep everything aligned. Guess the only way to find out would be to try it or follow a detailed procedure on the modification. Thanks guys at least I know it can be done.
yorkiejeff
F2 Tech
Aug 6, 2015 03:32 PM
kodeko
F2 Tech
May 18, 2011 09:50 PM
RojerLockless
May 4, 2011 02:15 PM
paddysasausage
Nov 20, 2007 12:07 PM
lococbrf2
Oct 17, 2007 05:33 PM
