Silicon rectifier
Old Jan 12, 2014 | 03:17 PM
CorruptFile's Avatar
June 2013 ROTM
Default Silicon rectifier
What is the purpose of it? Looks like it's in the clutch switch circuit. I am looking to bypass the circuit, but I am not sure if I want to run continuous current through the rectifier.
Old Jan 14, 2014 | 12:53 PM
highwaypatrol's Avatar
I am not sure which rectifier you are referring to. The only rectifier I know of is the Rectifier/Regulator that charges the battery by converting Alternating Current from the alternator into Direct C current.
Old Jan 14, 2014 | 02:38 PM
June 2013 ROTM
Thanks. That wasn't the rectifier I was thinking about. It's a small rectifier under the seat in the clutch circuitry.
Old Jan 16, 2014 | 06:11 AM
Hi. Looking at the photo it looks like some sort relay. Is your bike a CBR 600? If so I'll see if I can identify it in my Haynes manual (1996-)
Old Jan 16, 2014 | 09:26 AM
June 2013 ROTM
600F1. It's wiring diagram is here. The rectifier I am inquiring about is located above the pulse generator in this diagram. Thanks!
Old Jan 16, 2014 | 09:22 PM
CalKirley's Avatar
You're looking for a clutch diode as it's called on the F2 and F3. Look at how it runs to the clutch switch. That symbol is also a universal electrical symbol for a diode.
Old Jan 16, 2014 | 11:00 PM
June 2013 ROTM
Yeah, a simple rectifier is just a diode. Restricting current flow in one direction (AC to DC, for example) BUT - I'm after what the purpose of it in this circuit is?!
Old Jan 17, 2014 | 12:11 PM
CalKirley's Avatar
I'm going to make an educated guess, but I'm pretty sure that the circuit that the diode is a part of is the starter circuit for when you're in gear. It almost looks like it's there to trip a smaller relay in the starter relay to prevent you from starting in gear without the clutch pulled in
Old Jan 17, 2014 | 12:12 PM
CalKirley's Avatar
Ah I misread the above post. I'll think about it and reply back tonight
hmm
Jul 12, 2015 11:53 AM
NormF3
Dec 7, 2013 04:02 PM
rickster
Sep 12, 2011 04:47 PM
paul_schmd
Jul 19, 2010 04:54 PM
PlayfulGod
Dec 15, 2007 01:13 PM
