Scorpio Anti-Hijack HELP
Old Feb 5, 2006 | 09:57 PM
Thorax's Avatar
Default Scorpio Anti-Hijack HELP
I just installed the scorpio alarm on my CBR600rr '05. I was able to install the alarm and the Perimeter Sensor, I plugged in the Anti-Hijack to the accesory harnes, but did not connect the wires to the Ignition/Engine control wire. I'm not sure where this wire is at.
Old Feb 5, 2006 | 10:14 PM
doncollins's Avatar
Retired Administrator
Default RE: Scorpio Anti-Hijack HELP
From what I've read... the alarms are plug and play. Do you have wires left over to connect?
Old Feb 6, 2006 | 12:27 AM
MgA_ODEN's Avatar
Splice it off the kill switch.
Old Feb 6, 2006 | 10:19 AM
Thorax's Avatar
Default Kill switch
Where is kill switch located at. By the battery or up in the front under the gas tank.
Old Feb 6, 2006 | 11:14 AM
MgA_ODEN's Avatar
Default RE: Kill switch
Not sure if the 600RR is located at the same place as the 1000RR , Don your thoughts?
Old Mar 25, 2007 | 05:09 AM
mstw's Avatar
I have a 06 F4i and I also could not find the ignition wire. Does anyone know where it is?
If I can splice it off the kill switch, where would I find this wire?
Thanks,
Mike W.
Old Mar 25, 2007 | 12:38 PM
D2VW14_20's Avatar
You have to take the kill off the bar to access it.
Old Mar 25, 2007 | 08:16 PM
mstw's Avatar
thanks for the response... so once i remove the switch, is there a specific wire (color)?
dgk600f4i
Jul 1, 2012 09:19 PM
davethepom
Jul 10, 2009 03:03 AM
Orangebutter
Apr 14, 2008 12:17 AM
mudz_amin
Mar 12, 2008 10:32 AM
marcee77
Mar 17, 2006 11:36 AM
