Anti-freeze everywhere!
Old Mar 11, 2006 | 06:21 PM
marcee77's Avatar
Default Anti-freeze everywhere!
Hi guys, haven't posted in a while but I keep reading all the great posts weekly. So, finally got a nice day and I started the bike up for the first time in about a month. I left it running in my garage while I was inside on the throne. When I came out, my bike was overheating and the anti freeze was pouring out of the overflow hose. I shut it down, and fortunately there is a brand new bike shop literally two blocks from my house. So I rode it over, told the mechanic what happened and he says this-mind you I dont know this guy so I dont know how valid his opinion is- "Since your bike was sitting, the thermostat was probably just stuck and cause the bike to over heat, I'll fill your radiator back up and you will be good to go" Sounded fishy to me but I aint no mechanic. So then after letting it run for a little while 10 -15 mins, the temp hits 220 the fan never kicks on and his story changes to-The sensor that tells the fan to start is shot (for some unknown reason) and he needs to order it from Honda and he'll get it installed by Friday. All this make sense to you guys or should I be going to take my baby back from this shop today! I ride a 2001 F4i, Never had a problem with it, I treat it like my daughter. Any one have a price range on a job like this so I know if he's trying to rape me?
Old Mar 11, 2006 | 08:13 PM
scotty8583's Avatar
Default RE: Anti-freeze everywhere!
Start by checking the fuse first homeboy! I had a fuse blow for my fan, threw a new one in for .65 cents!
Old Mar 11, 2006 | 10:15 PM
chaos321's Avatar
The thermostat sensor is $54 on BikeBandit.com. It is number 19 on the parts breakdown, and the O-ring is number 21. It will take you longer to get your body work off than what it will take to change this switch. The shop is going to charge you a minimum of 2 hours to do the work at roughly $65 an hour. It's cheaper and easier to do it yourself, and learn something in the process. Hope this helps!
Old Mar 12, 2006 | 07:58 AM
shraz's Avatar
on my F4 the fan never came on and the coolant boiled
it was due to the fuse being blown
check the fan fuse
the fan comes on at 225 for f4i
Old Mar 15, 2006 | 11:27 PM
marcee77's Avatar
Hi guys- the mechanic says it was just a fuse. Next time i'll check all that myself before panicing and running to the shop! At least he didnt just tell me i needed a sensor to make some money off of me.
Old Mar 16, 2006 | 07:02 AM
shraz's Avatar
next time post here before going to mechanic
I could use that 100bux
Old Mar 17, 2006 | 11:36 AM
Kingpat's Avatar
I had the exact same problem last year. It was the fuse as well.
dgk600f4i
Jul 1, 2012 09:19 PM
woot
Nov 12, 2006 08:26 PM
ciceman
May 25, 2006 02:01 PM
revracingnj2000
Mar 6, 2006 06:23 PM
revracingnj2000
Mar 6, 2006 01:42 PM
