Reset buttons
Old Mar 18, 2006 | 08:50 PM
CBR600RRBLUE's Avatar
Default Reset buttons
I got a 04 RR and my reset buttons flipped out on me right after i bought the bike new and i didnt take it back to Honda for the warranty work has anyone else had this problem with your buttons, i did get me some more buttons but the little white internal buttons are loose and bounce around inside and there is no way to get them back in there place [&:]
Old Mar 18, 2006 | 09:13 PM
cbr04's Avatar
Default RE: Reset buttons
hmm... can't say that i've experienced that. hopefully another member can help out.
Old Mar 18, 2006 | 10:21 PM
05Tribal's Avatar
I remember another forum member having the same problem with their instrument mode setting buttons. Do a search for "buttons" or "button" and you should be able to find the posts.
Old Mar 19, 2006 | 12:14 AM
isolated1523's Avatar
Retired Super Moderator
I've got the same problem. Couldn't figure out how to get them replaced, so i just took 2 long objects (toothpicks, etc) and set everything how i needed it. Can't use the trip meter when i want, but at least i fixed the time. Sorry i don't have a solution though.
-Adam
Old Mar 19, 2006 | 03:34 AM
05Tribal's Avatar
You always have the option of buying a used instrument display off eBay.
Old Mar 19, 2006 | 11:55 AM
I got my time all screwed up on mine and the trip hasnt been used in quite some time, my buddy needs 1 for his 03 he high sided last summer and got his so i robbed the buttons but cant get them to work, thanks for the help
Old Mar 19, 2006 | 12:59 PM
duck0872's Avatar
I had the same problem. I ended up changing the led's in my speedo so I just fixed it while I had the gauges apart. You have to remove the front fairing, remove the gauge cluster, and then take the cover off the gauges. I used a little bit of glue to bond the plastic pieces to the buttons on the circuit board. But if you do this be careful, it would be really easy to permanently glue the buttons so they're always being "pressed". Hope this helps.
DevilInDisguise
Mar 18, 2012 11:20 AM
slapshot1540
Mar 9, 2012 10:13 AM
morganw
Feb 5, 2008 10:39 AM
SteeleCBR
Mar 23, 2007 03:24 PM
hypnotic
Jul 2, 2006 02:15 PM
