Removing trim clips
Old Aug 25, 2005 | 02:48 AM
p166mmx73's Avatar
Default Removing trim clips
Can someone tell me how to remove the trim clips under the rear tail of my F4i? I am speaking of the four screw near the rear passenger foot pegs. I've tried unscrewing them with a conventional screwdriver but it doesn't seem to be loosening the screws. Any help is appreciated. Thanks.
Old Aug 25, 2005 | 05:43 AM
p166mmx73's Avatar
Default RE: Removing trim clips
Ignore this question. I figured it out.
[sm=smiley9.gif]
Old Nov 7, 2005 | 10:04 PM
keemo's Avatar
So what is the best way to get them out?
Old Nov 7, 2005 | 10:33 PM
05Tribal's Avatar
If you are talking about the plastic fasteners that have the round flat head with what looks like a small round pin head in the middle then you push the pin head down and it releases the clip. To get it back in make it so the middle "pin" part is sticking out, insert the clip onto the hole then push the pin head in. These must be used on many different bikes because I've seen them for sale at parts shops ten to a bag. If I remember correctly they cost $10-$12 a bag.
Old Nov 7, 2005 | 11:12 PM
keemo's Avatar
Hi Tribal,
Yeah the 4 clips on the underside of the tail. So you push straight down in the center which will release the whole clip? (sorry, i am not near my bike but will be later) Thanks!
Old Oct 4, 2007 | 12:17 PM
TRIGGA_CBR's Avatar
SO will I have to remove the the trim clip from the inside of the fairing? Can I remove the clip from the undernearth the tail where the clip is located.. I don't have any good access to the clip from the inside..
mrcbr25
Feb 16, 2012 03:10 PM
Glocker23
Jan 12, 2011 07:04 AM
TranSition
Apr 5, 2007 01:31 PM
rws381
Aug 10, 2006 10:41 PM
USAF~AMMO
Mar 30, 2006 06:46 PM
