rear spring retard question
Old Mar 19, 2007 | 10:49 PM
snowboarding82's Avatar
Default rear spring retard question
I've looked on here and I'm stupid so I need a very detailed response. I want to set up my suspension and in order to set the sag I need to adjust the rear preload. I bought my spanner wrench and I've read that there are lock nuts on the spring but I don't see one. Do I just stick the pin of the spanner wrench into one of the little holes where the numbers 1 - 7 are and turn? I know I'm only supposed to go one number at a time or I could break something. I'm just afraid to really crank on the wrench and break something when I was supposed to loosen something else first. I guess from what I understand I just stick the pin in one of the small holes and turn.
Old Mar 20, 2007 | 12:07 AM
Tahoe SC's Avatar
Default RE: suspension retard
yes, stick it in the squares and pull. it will take some effort. watch out for you knuckles.
Old Mar 20, 2007 | 09:58 PM
Default RE: rear spring retard question
Ok so I basically put my crappy little spanner into one of the little holes and just about put all of my 230lb fat weight onto it and it didn't budge. I even busted out a hammer and put a wash cloth on the wrench handle and tried tapping it and still no go. Is there something different with the '06 F4i's does anyone know?
Mike
Old Mar 20, 2007 | 10:02 PM
Joker_114th's Avatar
Might be Ezier if ya take sum weight of it.
Old Mar 21, 2007 | 01:44 PM
DVSGVS's Avatar
^^^ and also try putting a little lubricant on there, i had the same problem but after a little lube, easy as pie. wd40, motor oil, just about anything will work.
Old Mar 21, 2007 | 07:41 PM
How would I take weight off the bike? If I throw it up on the stand all that does is raise the back of the bike up. As for lubing it up, I should just spray some WD40 all on the plastic black ring? I'll give that a try when I get home. I also picked up a wrench with a longer handle so maybe that will help.
Mike
Old Mar 21, 2007 | 07:56 PM
Tahoe SC's Avatar
no need to do anything to the rear...just stick the spanner in the square grooves and turn it...
the spanner is very short, you'll need to extend it some to get some leverage. then it WILL go.
Old Mar 21, 2007 | 10:31 PM
I finally got it to go. I got a new spanner wrench that was twice the length of the first one I picked up and could finally turn it. Although to get it onto setting 7 I had to put one of my riding gloves on and push freaking hard! Good times
Thanks again
Mike
CBRInfantry
F2 Tech
Mar 22, 2011 06:53 PM
thecrew66
Jan 27, 2011 08:01 PM
xricer
Nov 16, 2010 08:20 PM
TinMan
Oct 15, 2007 02:52 PM
CBR600F3ROX
May 2, 2007 07:46 PM
