Rear Brake Light Issue
Old Apr 24, 2007 | 01:12 AM
Da CbR KiD's Avatar
Default Rear Brake Light Issue
hey guys... i was wondering if anyone knows how to help me fix my rear brake light... i noticed today that the rear brake pedal is sticky... meaning when i press the rear brake pedal the light stays on even after i let go of my rear brake... i am worried that someone behind me won't know that i am hitting the brake... specially in hard braking situations... please help... thanks
Old Apr 24, 2007 | 01:15 AM
knightslugger's Avatar
Default RE: Rear Brake Light Issue
if the pedal is sticky, un-stick it... remove it clean it re-install it. simple. if it's the SWITCH that's sticking, then remove it, determine if it's worth fixing, decide to huck it and buy a new one, re install it.
Old Apr 24, 2007 | 01:23 AM
Da CbR KiD's Avatar
i'm really new with all this stuff so i've not a clue where the switch is... i can take the pedal off... but the problem is if i let go of the pedal it goes back up but the only way to turn the light off is to give the pedal a tug up almost like shifting up through the gears... but i will try to take the pedal off and put it back on
Old Apr 24, 2007 | 01:25 AM
ORIGINAL: Da CbR KiD
if you take the pedal off, you'll see a cylinder with a wire or two on one end and a spring attached to a rod on the other, which connects to the pedal. you've just found the rear brake light switch.
Old Apr 24, 2007 | 01:39 AM
Da CbR KiD's Avatar
sweet thanks for the info bro... i will be sure to take a look at it when i get a chance... wish me luck... i'll need it =P
Old Apr 24, 2007 | 01:41 AM
i doubt it...
zellster
Aug 19, 2019 06:44 PM
PancakeShake
Jul 2, 2010 11:01 AM
STRETCH15
Jun 27, 2010 05:11 AM
jam0837
Apr 6, 2010 04:49 AM
sodapopsmash
Jun 9, 2009 10:58 PM
