Rear Brake Lever and Brake light
Old Sep 28, 2006 | 12:00 AM
2rawcbr's Avatar
Default Rear Brake Lever and Brake light
I'm having a problem with the light coming on once the rear brake lever is engaged. The brake light doesn't come on, tried to adjust the brake lever but still no light until I apply a lot of pressure. Any suggestions? Oh yeah, its a '06 1000RR, Black.
Old Sep 28, 2006 | 02:12 AM
zerochickenstrips's Avatar
Default RE: Rear Brake Lever and Brake light
Directly beneath and behind your right side rearset is the rear brake light switch. You'll see a circular knurled "nut" and a long cylindrical plastic piece. In order to engage your brake light earlier with less pressure, you'll need to rotate the nut clockwise which will pull the switch toward the front of the bike. Make sure when you're spinning the nut that the switch isn't also turning. Keep turning the nut and pressing the brake lever until the light comes on when you want it to.
Old Sep 28, 2006 | 05:38 PM
roxy_33's Avatar
Its a real pain in the ***, There arent many things I dislike about my bike, but that one tops the list. (I have to adjust once a month or so.) but like Z chicken said, your probably turning the whole switch instead of the adjusting nut.
LilRed F3
Nov 30, 2011 07:14 PM
gambit07
Mar 30, 2011 02:25 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
mini bagels
Sep 4, 2006 04:31 PM
aeroworks
Feb 23, 2006 01:21 PM
