Rear Brake Lever and Brake light
Directly beneath and behind your right side rearset is the rear brake light switch. You'll see a circular knurled "nut" and a long cylindrical plastic piece. In order to engage your brake light earlier with less pressure, you'll need to rotate the nut clockwise which will pull the switch toward the front of the bike. Make sure when you're spinning the nut that the switch isn't also turning. Keep turning the nut and pressing the brake lever until the light comes on when you want it to.
Hayden06F4i
06-17-2008 09:50 AM
