Random Power Loss?
I have a 2005 CBR 600 RR, I had been riding it for about 45 minutes when I came to a stop light. Riding through the stop light it suddenly cut power and won't start. No display on the dashboard, nothing. Checked some of the connections and fuses, they all seem fine, it's a pretty new battery so I haven't taken it to be tested yet, but can anyone help me out? I'm fixing it on my own because I'm done paying jacked up rates for something I should be able to do on my own? Thanks
A completely dead bike usually indicates a blown fuse. The 30A main fuse is usually the culpret when nothing turns on when you turn the Ignition Switch to the On position. That fuse is on the Main Starter Relay.
Any luck?
make these measurements:
1. battery voltage with everything OFF
2. battery voltage when cranking with START button.
3. battery voltage at idle
4. battery voltage right after it dies.
These numbers may point to issues with charging system.
Larshurricane
Aug 3, 2022 10:50 PM
