raising the frame from the motor
Old Aug 7, 2008 | 12:18 AM
2180turbo's Avatar
Default raising the frame from the motor
I got a 2007 cbr 1000 that needed repair on the stator cover side. I have replaced the cover and now just have one last thing. Above the stator cover is a raditor hose that also has a smaller hose coming from it. I have to replace this peace. I can get to the bottom bolt, but the top on is behind the frame. what all has to be done to get to it. Looks as if I raise the frame just a 1/4 of an inch I could get to it. HELP NEEDED HERE> CALLING ALL TECH HEADS
http://i195.photobucket.com/albums/z...o/SSL10597.jpg
http://i195.photobucket.com/albums/z...o/SSL10600.jpg
Old Aug 7, 2008 | 09:43 AM
marc0011's Avatar
Default RE: raising the frame from the motor
Can you go at it with a combination wrench. They are nice and flat and can fit in really tight areas. It should be able to squeeze into that area between the frame. The other problem you might run into is that there might not be enough room to back out the bolt.
Old Aug 7, 2008 | 10:14 AM
2180turbo's Avatar
That was my first try. You can only get maybe two full turns onthe boltuntil ithits the frame.
Old Aug 7, 2008 | 10:23 AM
lonewolfcbr's Avatar
are you talking about that little peice that the rad hose attaches to thats bolted to the motor with two bolts? if so your gonna have a hell of a time with it...a buddy of mine had to loosen his rear motor mount to make that repair
ellispowdercoating
Oct 14, 2010 10:54 PM
Shattered1zDream
Jul 26, 2010 05:19 PM
95F3Fighter
Mar 24, 2010 08:46 AM
hondaking69
Sep 8, 2009 07:33 AM
Sand.Man
Mar 29, 2009 10:55 PM
