Radiator Flush
Old Oct 8, 2008 | 01:35 PM
txn_driver's Avatar
Default Radiator Flush
ok so i was outside messing with my bike earlier and i decided to check up on everything and my radiator looks really nasty inside, my question is, should i buy radiator flush from autozone or does it take a special kind? or can i just unhook my bottom radiator hose and put a waterhose in the intake and flush it that way, i know the proper way is run the motor, drain, etc. but i cant get the bike to start right now so what do you guys think? Also i want to add that the last time i actually rode it rode it the bike got too hot and shut off, however ive started it up and ran it since then, no cracked headgasket, etc etc.
Old Oct 8, 2008 | 11:33 PM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: Radiator Flush
You dont needa flush kit. Just pull a hose as you stated and run the hose to it. Up here where it gets cold we hand flush heater cores in cars all the time. The main thing is when your done it will be full of straight water, so you may have to run it, drain it, a few times to get a good coolant mix back in there. Or if you have a compressor you can (gently) blow it all out with an air hose (no more than 15 psi).
Old Oct 9, 2008 | 12:46 AM
txn_driver's Avatar
sweet, ill roll it over to the compresser tommorrow
Old Oct 10, 2008 | 08:47 PM
toptaz1000rr's Avatar
drain it out a few times never use something for/from a car for our bikes... additives dont like aluminum bike engines lol ... bike stuff is specialized for a reason
Old Oct 10, 2008 | 10:21 PM
TK954RR's Avatar
Jan 2009 ROTM
^ Who said anything about using something for/from a car? As far as antifreeze you can use almost any type/brand designed for an aluminum engine safely. Some of the older antifreezes have silicates in them which will cause premature wear on the water pump, but most new blends dont, so just read the bottle.
boink1079
Jan 15, 2009 07:49 AM
waz57
Nov 2, 2006 03:06 PM
BigWill
Jul 31, 2006 04:13 PM
MarkR
Apr 15, 2006 03:04 AM
Oscar
Dec 12, 2005 01:28 AM
