Radiator Flush??
Old Jan 13, 2009 | 06:46 AM
boink1079's Avatar
Default Radiator Flush??
My Cane is now back together and I was tempted to use a radiator flush through the cooling system - the flush is designed for alloy engines - anyone flushed the system? is it good to check the thermo etc ? its usually 39/40 degrees celcius over here and we know the Cane's hate the heat...
Old Jan 13, 2009 | 07:46 AM
hawkwind's Avatar
Default RE: Radiator Flush??
The Haynes manual says any flushing agent can be used so long as it is for aluminium engines , so you should be ok , just follow the instructions on the pack . It also says you can reverse flush the radiator by putting the hose in the 'uppermost ', I suppose that means the top hole
Old Jan 14, 2009 | 05:48 AM
bluebeard's Avatar
Be careful with engine flushes. They have a nasty habit of scouring all the scale off & dumping it into the top tank of the radiator & blocking it. If you need to flush it in such a manor make sure you remove the thermostat & reverse flush after the cleanusing a proper fitting that uses water & compressed air. That way all crud is blown out once the clean is done. You can also use a filter sock on the radiator inlet to catch the scale. Both items should be available from your local auto shop. Hope this helps.
Old Jan 15, 2009 | 03:29 AM
bluebeard's Avatar
I found out the hard way many years ago in an old Holden. Since then I've stayed well clear.
Old Jan 15, 2009 | 06:59 AM
Shadow's Avatar
If you use the right mix - distilled water/antifreeze, rad should be good indefinitely. It's the non-distilled water that causes the problems. I drained and refilled mine recently, no scale, nothing.
Reverse flush as Blue suggests, and all will be well.
Old Jan 15, 2009 | 07:49 AM
boink1079's Avatar
Guys, I'm glad I asked. Thanks!
txn_driver
Oct 10, 2008 10:21 PM
waz57
Nov 2, 2006 03:06 PM
BigWill
Jul 31, 2006 04:13 PM
MarkR
Apr 15, 2006 03:04 AM
Oscar
Dec 12, 2005 01:28 AM
