Radiator Flush
Old Apr 14, 2006 | 05:58 AM
MarkR's Avatar
Default Radiator Flush
I plan to flush the radiator this weekend
When I brought the bike last year, there was no coolant, just water
I want to dump the water, flush out the system and refill with coolant (50/50)
I figure that I would remove the fairing, disconnect the water hose on the lower left of the bike and flush though the radiator cap. Any subjections before I start.
Old Apr 14, 2006 | 06:25 AM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Default RE: Radiator Flush
Hey:
Unless you are going into a colder climate, during the hot summer try water wetter and plain old water it runs cooler, then just add coolant
antifreeze 50/50 when you store for the winter as part of the winterizing of your bike.
Old Apr 14, 2006 | 08:42 PM
MarkR's Avatar
Winters are not as cold here, as there, I expect, So the bike gets used year through
In Queesnsland, Australia, winters are cool, summers are Hot (What's Snow?)
My temp gauge always sits about ¼ until I have to stop for lights or traffic, then it gets hot and usually the Fan kick in.
I also want to run coolant to protect the engine from corrosion
Old Apr 15, 2006 | 02:50 AM
CBR1988's Avatar
Hey:
The water wetter product does help against corrossion and build up, it also runs 10-20 degrees cooler than 50/50 mix anti freeze
and should have a simular product base in OZ, it is a bottle to a couple of gallons of water and is the answer to hot wx. I started using
it in the desert and was the only thing that worked in that heat besides removng the thermostat core and spring, and putting on/off switch
inline on the fan. it never overheated/got hot even though I did.
Old Apr 15, 2006 | 03:04 AM
MarkR's Avatar
I was thinking of putting a switch on the fan so when you get in traffic, you can initiate the fan yourself, or maybe have it wired to the neutral switch so it comes on in neutral
boink1079
Jan 15, 2009 07:49 AM
txn_driver
Oct 10, 2008 10:21 PM
waz57
Nov 2, 2006 03:06 PM
BigWill
Jul 31, 2006 04:13 PM
Oscar
Dec 12, 2005 01:28 AM
