Quick question about wiring to a ground
Old May 16, 2007 | 05:28 PM
chpsk8er630's Avatar
Default Quick question about wiring to a ground
Where can i wire a ground to? I should be able to attach a ground to anywhere on the frame or subframe right? or do i have to wire a ground to the battery?
Old May 16, 2007 | 06:38 PM
therabbit's Avatar
Default RE: Quick question about wiring to a ground
What are you grounding? Technically yes, you can ground to anywhere on the frame, but the quality of the connection desired is what will determine if you want to ground there or run a cable to the battery.
Old May 16, 2007 | 08:11 PM
Rick619's Avatar
I thoughtaluminum doesn't make a good ground, does it?
________
Ffm blonde
Old May 16, 2007 | 11:39 PM
ky_wildcat's Avatar
Find out where you battery is grounded to. If it is big enough you may be able to attach there.
iceman423
Aug 9, 2019 10:48 AM
this guy
Nov 23, 2013 10:15 AM
halik008
Nov 6, 2007 09:57 AM
Nobble
Jul 23, 2007 06:12 PM
