Please help with this Yoshi TRS
Old Dec 6, 2006 | 01:28 AM
dejvan's Avatar
Default Please help with this Yoshi TRS
I have Yoshimura TRS Bolt-on can, 3 bolts pattern. I didn't find any part number on it and I'm trying to find out, what bike this pipe will fit. I have some measurements... 3"1/8 between the bolts and 2"1/8 pipe hole, where mounting. If you know, what bike is this pipe for, please let me know. Thanks
[IMG]local://upfiles/12746/B0C20EE14BF24D3AA19C7D13CE1F9650.jpg[/IMG]
[IMG]local://upfiles/12746/A29B19BB15F141829CA86D23E9FF9316.jpg[/IMG]
Old Dec 6, 2006 | 03:38 AM
dragonium25's Avatar
Default RE: Please help with this Yoshi TRS
Where did you get it? Pretty hard to tell what bike it fits just from the can. If you had the mid-pipe that might help a bit, but it's still a needle in a haystack.
Old Dec 6, 2006 | 11:46 AM
dejvan's Avatar
It came with my bike and I was told, the pipe is for it. I didn't pay attention to it and found out week later, that stock can is not bolt-on.
Edit: add new pic
Old Dec 8, 2006 | 12:01 PM
900RR Puzzle's Avatar
This looks like a canister desinged to bolt on to a stock exhaust pipe. My 900RR has a similar bolt pattern. I'm pretty sure that the 929 and 954 also used a similar set-up. One thing that is different between different years of the 900RR, the 929, and the 954, is the orientation of the bolt patterns, to how the canister lines up. For example, I have a 95 stock pipe on my 97 900RR. I purchased a bolt-on canister (used) for it, thinking that all 900RR years were the same. It bolts to the pipe, but the oval canister sits on an angle, instead of straight up and down.
I went out and measured the stock 95 can that came with the pipe. The mounting bolt spacing is actually 3 1/8", but the pipe hole is about 2 7/16" (larger).
It's hard to tell what model Honda that goes to. My knowledge on this would only be for 900RR's. I don't think that it is for a 93-97 900RR, because the hole diameter is too small.
Hope this helps.
Old Dec 9, 2006 | 09:11 PM
dejvan's Avatar
Hey, Thanks Puzzle. I also foundout, that some Kawis use 3-bolts pattern, but still no 100% sure what bike is this pipe for. The only reason I'm trying to findout is to sell it faster. I tried to sell it localy, but it'll go to ebay tomorrow.
NateDieselF4i
Jun 30, 2011 01:04 PM
boost90
Oct 5, 2007 12:39 PM
trafficsucks
Oct 4, 2007 01:14 PM
Brucewayne678
Feb 16, 2007 07:04 PM
Threeonethyrd
May 8, 2006 12:13 AM
