PLEASE HELP - LED TURN SIGNAL INSTALL
Old Dec 22, 2005 | 03:15 AM
Truckie973's Avatar
Default PLEASE HELP - LED TURN SIGNAL INSTALL
Please someone help I have an 2006 CBR 600rr and Im trying to install the hot bodies flushmount LED's. I see that there are three wires comeing from the bike and two wires comeing from the actual LED. i have no clue what goes where.
Old Dec 22, 2005 | 07:36 AM
roxy_33's Avatar
Default RE: PLEASE HELP - LED TURN SIGNAL INSTALL
Your new LEDs do not have a provision for running lights.(constant on) Hook up your ground, (on my 1KRR its the green wire) and hook up the led to the flasher wire from the bike. (I think its the orange/blue without the stripe.) You can make them work as running lights also, by hooking up both orange and both blue to the positive on the led`s but this will also cause the rear signals to function as running lights too, (and it makes the signal indicators on the instrument cluster stay lit) unless the flasher is on. I have them both hooked up on my 1K because I dig the way it looks......
I hope that helped.... I`m too drunk right now to make further explaination, but it makes perfect sense to me.... (Thats a comfort, I know )
Old Dec 22, 2005 | 08:39 AM
doncollins's Avatar
Retired Administrator
ahh... drinking and typing, bad combination. Good tips, but can you guys post up some pics and let us know how bright they are? CJ and I are looking about buying them.
I meant to add: roxy_33, you aren't concerned about having two positive leads going to the same source?
Old Dec 22, 2005 | 04:59 PM
Truckie973's Avatar
Thank you for your help it was the solid green and the solid blue. But someone also told me I can use them as running lights and turn signals. Any clue on how to do this???
Old Dec 23, 2005 | 02:28 AM
roxy_33's Avatar
ORIGINAL: doncollins
Not at all.... on my bike the running light positive stays on unless the blinker is activated, then the running light lead turns off, and the flasher lights up. Both positive wires are never hot at the same time..... I`ll see if I can get pics loaded.
Old Dec 23, 2005 | 02:48 AM
roxy_33's Avatar
Heres the running light hooked in and powered (in lit garage)
[IMG]local://upfiles/2863/9603FFC923F64EDD98023D6E794169AC.jpg[/IMG]
Old Dec 23, 2005 | 02:53 AM
roxy_33's Avatar
but when you hook in both positive wires, the rear signals will also function like running lights.
[IMG]local://upfiles/2863/C04E27F6808E4FC3A575F8EE209B87CF.jpg[/IMG]
Old Dec 23, 2005 | 02:55 AM
roxy_33's Avatar
with blinker activated.....
[IMG]local://upfiles/2863/44C990CBD9DC4378B0E6642B105613EB.jpg[/IMG]
Old Dec 23, 2005 | 02:57 AM
roxy_33's Avatar
And in the dark...... (the signals are really brighter than this, but my cam has automatic filters that won`t turn off....)
[IMG]local://upfiles/2863/09B108045A7A46AD93CE5D139435923D.jpg[/IMG]
Old Dec 23, 2005 | 09:40 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Doesn't matter if both positives are hooked up because the bike only puts out 12V -- the worst thing that could happen is that the running light would stay on and no blinky blinky.
Decah
Jan 30, 2009 12:29 PM
rex4mayor
Jul 23, 2008 11:44 PM
Gzilla1985
Sep 15, 2007 03:11 AM
de goose man
Dec 18, 2006 11:27 AM
