HELP!! running light on dash does not work after hotbody flush turn signal install!!
Old Sep 19, 2008 | 10:27 PM
Cun0144's Avatar
Default HELP!! running light on dash does not work after hotbody flush turn signal install!!
Hi, I just completed the Hotbody Flush mount turn signals in the front. I set it up with 2 diodes on each side to where the turn signals act as running lights also. Everything worked fine, then after i put all the fairings back on and everything i realized the light on my Dash where the tach and speed readings are does not turn on. The turn signals are not running lights either but they do turn on when i signal left or right. Im thinking i may have shorted the wire somewhere while putting the fairings back on? It is such a pain in the butt to take all the fairings back off to inspect just wondering if anyone else knows Thanks!
Old Sep 19, 2008 | 10:34 PM
FLYOU's Avatar
Default RE: HELP!! running light on dash does not work after hotbody flush turn signal install!!
sounds like you jarred a pin loose in the front harness connecting the cluster. when was the last time you waterproofed/cleaned them? a little nudge is all it takes sometimes (it's happened to me about 3 times in the past year).
yeah it sucks, but i'd rip that front fairing off and clean/lube all your connections again. it's supposed to be done once a year or so anyway. might as well get em while the fairing is off.
Old Sep 19, 2008 | 10:37 PM
Cun0144's Avatar
Which connectors are you talking about? Also ichanged out the OEM light bulbs for PIAA light bulbs if that has anything to do with it? but the headlights are working fine.
Old Sep 19, 2008 | 11:08 PM
Cun0144's Avatar
OMFG....after taking all the fairings off to inspect everything was fine (I knew my i did a good job soldering and insulating those wires). THen i started thinking what could it be. So i go check the fuse box turns out theres a blown fuse....wow a 5minute task turned into 30-45minutes lol. I just hope this isnt an ongoing problem with the blown fuse
Old Sep 20, 2008 | 07:16 PM
repyosol's Avatar
If its a blown fuse you might shortend a wire check if the ground is hooked up right. do you have a f4i manuel it shows the diagram. But i know the ground is always black but im sure the ground on the f4i are green.
bigryanjackson
Oct 20, 2011 11:08 AM
dohcdelsol
Mar 10, 2010 08:41 PM
sharker98
Dec 4, 2007 09:58 PM
wande00
Sep 27, 2006 07:39 PM
