PC III Problem!!
Old Jul 15, 2006 | 01:02 AM
RR4me's Avatar
Default PC III Problem!!
I just put in a PC III on my '06 and I must have hooked something up wrong because now it won't start.I have already put everything back together so I was trying to avoid taking the tank loose and all the extra that goes with it. Any suggestions or help??
Old Jul 15, 2006 | 01:28 AM
chaos321's Avatar
Default RE: PC III Problem!!
Check your connectors. I know on the F4i there were two connectors that were exactly alike, and I hooked my PCIII up wrong the first time as well.
Old Jul 15, 2006 | 08:13 AM
RR4me's Avatar
I hooked it up to the lower injectors just like the pictures/directions said. The only thing different now is that there is no sound of the fuel injection running just before hitting the starter button.
Old Jul 15, 2006 | 12:01 PM
doncollins's Avatar
Retired Administrator
What about the throttle position connection.... it's a bitch to get to, are you sure its' tight?
Old Jul 19, 2006 | 09:03 PM
RR4me's Avatar
The problem is in the 5th plug-in. I pretty sure that the lower FI are hooked right. It 's the 5th plug in that is casuing my problems. I can't tell a lot from the picture that is on the directions that come with it. I plugged it in to a connector just above the 2nd and 3rd FI. That is what caused my problem. I unhooked that connector and it started right up. If that's the wrong connector where is the right connector??
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
