Painting the Engine?
Old May 20, 2012 | 01:06 AM
Shiffts's Avatar
Default Painting the Engine?
I'm looking to paint the engine black.
Is there any advice/how to that I could follow that will give me a nice, finished product?
I know I need to use high temp paint and plan on using it on the engine & exhaust header.
Old May 20, 2012 | 04:30 AM
CJardine's Avatar
Track junkie & modaholic
I would recommend swinging o over to the general tech forum and asking there, this forum is normally used for people explaining what to do not asking questions so you might have better luck there.
Old May 20, 2012 | 05:50 AM
MadHattr059's Avatar
Good point, CJ.
I've moved this to General Tech, Shift. Hope the move will get you
better answers.
Ern
Old May 26, 2012 | 01:15 AM
Shiffts's Avatar
Bump due to no results?
Old May 26, 2012 | 06:09 AM
MrHEX's Avatar
Ive painted a few engine blocks, i would imagine the process being the same.
you need to take it all apart an give it a good cleaning with some kind of cleaner or paint thinner or both. the idea is to not paint the gaskets and to prep the surface as best as you can.
then tape up what you don't want printed and give it several coats of THIN layers of manifold paint. the options are limited but it works the best.
as for your exhaust, not sure what you can use, see if you can find a shop that does anodizing, (kind of looks like its blue/burnt on the tip) you can also (depending on how far you want to go) wrap it then spray ceramic paint on it in different colors.
this may or may not be an option you want to take.
the muffler is easier since it doesn't get as hot as the exhaust pipe it self.
cbr6rider
How To: Paint and Body
Jun 16, 2014 04:15 AM
cbr6rider
Mar 30, 2012 09:08 AM
egdcbr600rr
Jan 2, 2009 12:19 PM
Glocker23
Nov 28, 2007 06:55 PM
JMart
Nov 8, 2007 09:59 AM
