Over heating
Old Aug 5, 2006 | 12:09 AM
matt42van's Avatar
Default Over heating
My 600 f4 seams to be very touchy in daytime heat while idling. Just going through town after a couple of stop lights on a hot day and it will actually stall out. This has happened as I am gearing down for a turn off as well (when the bike is not all that warm). Any thoughts?
Old Aug 5, 2006 | 04:59 AM
NOchknstrips's Avatar
Default RE: Over heating
First of all have you checked all of your fluid levels. I know its a little thing but gotta knock those simple things out. Next would be have you messed with the timing. I know sometimes advancing the timming will over heat the engine and cause heat soak. Umm check your radiators and make sure nothing is in there clogging up. Also when it overheats is your gauge showing it?
Old Aug 5, 2006 | 07:10 AM
shraz's Avatar
what rpm is it normaly idling at a stop light?
does your radiator fan work? should kick in around 220+ F
Old Aug 15, 2006 | 09:43 PM
matt42van's Avatar
I have checked the cooling level, it's fine... The fan does kick in but it just doesn't seam to do the job. I am thinking that it is the thermostat or a plug in the line. At a stop light it is reving pretty low around 500 rpm's and I don't know the exact temp it's not a dig display. Thanks for the info any other hints?
Old Aug 15, 2006 | 10:32 PM
shraz's Avatar
there you go 500rpms is too low
up it to 1400
Old Aug 16, 2006 | 01:39 AM
slowpoke's Avatar
And the thermostat is pretty low tech and less than $30. And not hard to replace.
mnguyen84
May 26, 2009 06:08 AM
99honda
Aug 2, 2006 01:22 PM
sfoletta73
Jul 27, 2006 04:05 AM
600f4ika
Jul 6, 2006 12:37 AM
addaiaway
Jun 26, 2006 02:41 PM
