954 Heating?
Old Jun 23, 2006 | 01:52 PM
sfoletta73's Avatar
Default 954 Heating?
I just recently bought a 03’ CBR 954. I got a reasonable deal on it and loved it for the last few months. I recently have noticed that the bike will jump temperature like crazy (will move up from cold start to 177 in like 1.7 mins) and run at 210 – 220 standing still and then fluctuate while moving (mostly 180 in the wind). I checked my coolant and it is good. I was going to change the oil, but it looks clean. Any other suggestions on what I should do? Should I just flush it all? HELP! SUMMER IS COMING!
Old Jun 23, 2006 | 02:39 PM
arkas's Avatar
Default RE: 954 Heating?
Totally normal believe it or not. My 54 does the same, it hates sitting in traffic but once you get moving its fine.
Old Jun 23, 2006 | 03:12 PM
sfoletta73's Avatar
Yours does that too? Man i just think that is alittle to hot while sitting at a light! Should i Flush my whole system and run a certain oil and radiator solution?
Old Jun 23, 2006 | 06:13 PM
wiz's Avatar
wiz
that's just how it is. i usually stay at the 180 range also. highest has been 210.
we'll see when this texas heat really starts kicking in.
there's another thread on here about the same subject and everyone seemed to agree it was normal.
Old Jun 26, 2006 | 03:20 PM
sfoletta73's Avatar
Hey, I check my bike out this weekend and it flucuated between 210 and 225. That is way not right because I know it would have went higher if i let it! what is the first thing i should look at or do? i checked the hoses on both sides and they were both MAJORLY HOT! (206). I am thinking that my thermostat is not working or improperly...WHAT SHOULD I DO??????
Old Jun 26, 2006 | 08:49 PM
benny's Avatar
I actually think it is normal man. mine runs as hot as you said yours does, and I mean the higher one. One way you could cool it down is by running a coolant called 'Ice", or "Blue Ice", something like that. You can pick it up at any bike store, and they will know what you are talking about if you mention those two names. It will help.
Old Jul 13, 2006 | 03:19 AM
ejase's Avatar
I talked to my buddy about the heat coming from my 954 and he suggested me to buy a billet radiator fan. he said it should help keep the bike down alittle cooler along with wetter water. The problem is finding a place that sells the billet fan. If anyone knows a site that sells it, shoot me a link.
Old Jul 13, 2006 | 03:26 AM
David96Z's Avatar
I don't see how a billet fan will help the situation. Water Wetter will help somewhat. My 954 runs about 180 while moving and around 210-215 at stop lights, I think it is what it is.
Old Jul 13, 2006 | 09:01 AM
DANK$OLDIER's Avatar
I was at the same temp as you 190-225 here in Denver, just flushed and replaced with ENGINE ICE and am now running 169-208, the majic blue coolant runs about 14-17 bucks per 2 qts and you need almost 4 qts ( two bottle's). btw I am running hp4 in her, hope this helps.
Old Jul 13, 2006 | 07:25 PM
machfive's Avatar
My 954 averages around 180 degrees while riding, but as soon as I sit and idle at a long traffic light, the temperature will climb to between 215-220 degrees. I have never seen it go above 221 degrees even in a hot and humid New Orleans summer. Try water wetter. This will penetrate deep into the pores of the metal in your engine and radiator and allow it to dissipate the heat more efficiently.
