One time headlight issue (for now)
Old Sep 10, 2011 | 10:47 AM
ubengineering's Avatar
Default One time headlight issue (for now)
It's been raining a lot in Buffalo lately so up until yesterday it's been about 8 days since I've riden.
I turned the key to on and the light (headlight) came on as usual, so I fired it up and the light went out. Figured I had a dead bulb so I turned on the high beams and nothing.
So I turned off the bike, key to the off position and fired it back up and both lights are functioning as normal. Worked fine this morning on my way into work as well.
Maybe a sticky switch?
Old Sep 10, 2011 | 02:37 PM
Power to the headlights runs through the Starter Switch. This allows for the headlights to be turned off while the engine is trying to start. Your contacts may dirty in that switch, or a common problem is that the solder connection where the wire attaches to the switch breaks loose. The thing that points me to the Starter switch is that neither the High or Low beam were working. If it's working now, well you've got some ideas to help if it comes back.
Old Sep 16, 2011 | 09:13 AM
Bump, this now happens freqently, if i flick the switch on and off the lights will eventually come on, anyone have any tips/tricks to take apart the switch/loosening the cables (i see there's two)
Old Sep 16, 2011 | 04:16 PM
There is 2 screws that hold the housing together. It's easier to take apart if you remove the Clip-On from the throttle handle. It slides out, then it's easier to work on the switches. I take the Clip-On off the fork tube, split the switch assembly apart, slide the handle out of the throttle, then tilt the throttle out of lower portion of the switch assembly. Put it back in reverse order when you've figured out what is causing the lights to go out.
This is what I do on F3's, not sure about your particular model.
skullrider
Apr 13, 2020 01:48 PM
Julian_G
Aug 27, 2014 07:16 AM
Endless
Jan 19, 2009 06:50 AM
2005RX8
Sep 28, 2008 10:52 AM
cafrin100
Apr 30, 2007 01:05 PM
