06 f4i headlight issue
Old Jun 6, 2014 | 01:55 AM
Julian_G's Avatar
Default 06 f4i headlight issue
a couple weeks ago both my head lights just stopped working. All my other lights work well. the bike starts right up. fuse checked good. light bulbs didnt seem to be burnt out, but who knows. guy at the parts dealer said its to fishy for since both went out at the same time. anyone got any hints?
Old Jun 6, 2014 | 06:19 AM
74demon's Avatar
Don't overlook the bulbs being blown. A overcharging charging system can blow them both at the same time. Try a different bulb and check for power there at the connector.
If that doesn't do it, start looking at all of the connectors in the circuit. There is one that connects the front and main harness that has been known to have issues.
Also, look at the start button. If it gets stuck in just a little, your lights won't work.
Old Jun 6, 2014 | 11:39 AM
Incompatible's Avatar
Easy check for a sticky start button. With ignition off, push in start button and let it snap back several times. Start your bike and see if you've got lights. If you've got lights, a shot of aerosol lubricant of your choice into the switch should take care of your problem. A sticky switch lever doesn't return fully to engage the light circuit contacts.
Old Jul 6, 2014 | 05:20 PM
Julian_G's Avatar
ive tried the sticky lever tip, and still nothing. i heard it could be the switch itself?
Old Aug 25, 2014 | 04:30 PM
Julian_G's Avatar
i swapped out the relays in the headlight housing. my next guess is the switch, but does anyone know how to change these?
Old Aug 27, 2014 | 07:16 AM
cybernoid's Avatar
Does your passing light work?
If so, I had this problem myself and after going through the wiring trying to trace the issue, I found a contact inside the starter switch housing that had its solder broken off. Couldn't see it at first, I had to poke it to see it was off. After soldering it back on, everything works perfect.
It's the Red wire in the following picture (not mine, so ignore the "broken" arrows):
Hope this helps to solve your issue.
itsme71190
Jun 18, 2011 08:40 PM
AggieLawyer
Sep 17, 2009 10:37 AM
2005RX8
Sep 28, 2008 10:52 AM
vietladin
Jan 14, 2008 11:57 PM
cafrin100
Apr 30, 2007 01:05 PM
