oil question...
Old Aug 18, 2013 | 11:13 AM
ceebear's Avatar
Default oil question...
Im just getting it up and running after sitting for 6 years (long story). Heading into late summer/fall what oil should I use? And should i go conventional, blend, or full synthetic. Ill be using a K&N oil filter. Any other setup suggestion are welcome, thanks.
Old Aug 18, 2013 | 11:29 AM
74demon's Avatar
The oil subject has been discussed many times. If you do a search, you will turn up dozens of them.
What it boils down to is:
1. Use oil for motorcycles. It must be JASO-MA certified for wet clutches.
2. Use a weight that your manual suggests for your climate.
3. Make sure to keep it full and change it regularly.
4. Regular or synthetic is up to you.
Old Aug 18, 2013 | 11:37 AM
ceebear's Avatar
I had no idea about the JASO-MA cert, thank!
odano1988
Sep 15, 2015 07:26 AM
bammerman
Jun 12, 2010 12:32 PM
600f4iHUNTERDON-NJ
Oct 8, 2009 10:30 AM
sempul
Sep 11, 2009 09:38 PM
viva_brasil
Jun 9, 2008 04:38 AM
