oil problem..... no solution !!!
Old Mar 13, 2008 | 04:49 PM
jamaicandread01's Avatar
Default oil problem..... no solution !!!
hello everyone.......
it seems i have a small dilemma....
IT REALLY MIGHT TURN OUT TO BE A LARGER PROBLEM BASED ON MY ANSWERS BACK.
i'm puting oil in my bike right.
changing the filter as well.
for some reason the oil is not reading in my mirror.(glass in which oil is visible through fairings )
maybe it was too full, right..... and i couldn't see the level because it surpassed the fullness.
i just dumped it out..... and it looks the same as when i had 3 (three) quarts in it.
what's going on???
1)not enough oil ???
2)just perfect, and just deal with the way the oil - screen looks.(glass)???
3)it's busted and leaking inside of the bike itself ??? [:@][][>:]
4)too much oil ???
5)glass is not registering ???
thanks for your time of day everyone!!!
(561) 827-3817
Brian Roomes
[IMG]local://upfiles/24548/7FBF8309F0C248C39162689483767C65.jpg[/IMG]
[IMG]local://upfiles/24548/8AC42FFE169D4551849B93105B8760F7.jpg[/IMG]
Old Mar 13, 2008 | 05:20 PM
mycvil's Avatar
Default RE: oil problem..... no solution !!!
You are standing the bike upright before reading the glass correct? - It is almost a 2 person job - one to straighten it up, and one to look and verify the level.
Old Mar 13, 2008 | 05:50 PM
bluej511's Avatar
Im going with mycvil on that one. friend of mine did the same on his harley and ended up adding a quart because of it hahaha i laughed so hard
Old Mar 13, 2008 | 07:08 PM
white99gt's Avatar
ORIGINAL: mycvil
+2
Bike has to be in riding position aka uprite to check it.I can do it alone but some may need a hand.
Also 3qts isnt enough with filter its a touch over 3.5qts (depending on the filter you use).
Old Mar 14, 2008 | 12:09 AM
mauthman's Avatar
make sure you fill the filter before you put it on too... cuz if you don't you'll have to add a little extra... then straight up like everyone said.
When you start it the oil light should go off with in a couple of seconds and you should be good to go! Just watch it the first couple of rides and make sure the drain bolt is torqued! Good Luck
Old Mar 14, 2008 | 05:00 AM
pacemaker's Avatar
I hate the glass viewers, anyway my 2 cents, The oil you have put in is very clean, often when you put the new stuff in you can't see because of its translucency, especially when it above the top of the window.
Old Mar 14, 2008 | 07:42 AM
MikeInCtown's Avatar
They don't use dipsticks on the newer bikes? Did not know that.
My bike takes something like 4 quarts 3.xx liters. if I only has 3 quarts in there it wouldn't hardly register on the dipstick.
As with the person above, new clean oil is hard to see, even on a dipstick when you have light. Many times you need to look for the shiny wet spot.
Old Mar 14, 2008 | 09:07 AM
D2VW14_20's Avatar
No. Atleast mine doesnt.
Halibag
Mar 30, 2014 02:22 PM
ghostrider954
Aug 16, 2012 10:39 PM
Cujo98
May 10, 2011 05:07 PM
florida f4i
Jul 17, 2009 04:49 PM
demonchild
Jan 21, 2008 10:07 PM
