Oil Leak
Old Jun 8, 2009 | 10:40 AM
Leaky's Avatar
Default Oil Leak
Got a leak from in front of the block on the right hand side CBR 600F
It's from the end of the fairing bracket and somebody tried to 'plastic metal' repair.
What's behind the casing on that side. There are two parts to it.
Hoped to fix it from inside????
Old Jun 8, 2009 | 05:36 PM
squiggy16us's Avatar
Try taking some high temperature silicone and put on there. Splitting the cases is going to be costly
Old Jun 9, 2009 | 06:15 PM
Leaky's Avatar
Default Oil Leak
Only want to see from inside cover what caused leak originally.
Seems the pulse generator is behind cover.
Plan on grinding off 'plastic metal' and redoing it but I want to see how bad problem is first.
Old Jun 9, 2009 | 07:40 PM
Yeah that'd be a good idea. You dont need anything loose floating around in there. Good luck
ko67
F2 Tech
Sep 20, 2011 10:47 AM
vegas_rebel
Aug 28, 2011 12:10 PM
graysonwittwer
Aug 17, 2011 05:40 PM
amir145
Sep 1, 2010 11:33 AM
airick
Apr 17, 2007 06:58 PM
