Noise under braking as coming to complete stop
Old Apr 29, 2014 | 01:58 AM
geez's Avatar
Default Noise under braking as coming to complete stop
Hi guys,
I tried searching for this, generally the response was that it's normal but nowhere could I find a solution. I just had the brake pads on my 600 F3 replaced, front and rear. Works great, however as I'm coming to a complete stop, from ~15 km/h and lower there is a lot of noise coming from the front brakes.
From what I read this isn't harmful. I've done about 1500km with them, although about 1300km was a long distance trip with relatively little braking. The bike has about 64k km on it.
However it's quite loud, turning heads as I stop at traffic lights. So I'm looking to resolve the issue or at least reduce the noise. Any suggestions?
Thanks!
Old Apr 29, 2014 | 03:44 AM
Mattson's Avatar
Copper paste on slide pins and the "horns" at the ends of the pads MIGHT reduce the squeal, some pads, specially cheap ones, just squeal and there's not much to do about it other than buy better ones the next time round. I once had to re-replace a full set to my old Vw Passat cause they were screaming at low speeds even when not braking, taught me to not cheap out on them...
Old Apr 29, 2014 | 04:41 AM
Kiwi born's Avatar
Take them out and file a 45 degree edge on them. Works on most pads in bikes and cars. If there was no noise prior to the new pads being installed I'd file them and if still making noise I'd change the brand to a reputable one.
Good luck
Old Apr 29, 2014 | 06:15 AM
Pugheaven's Avatar
What make of pads? Cheapo pads will always do this, I use EBC on both cars and bikes and never had a single squeal...
Old Apr 29, 2014 | 06:44 AM
gtcole's Avatar
Welcome Crew
Kiwi born and Mattson both have good suggestions. The paste, or "caliper lube", the lil pack that comes in auto brakes, cuts down on squeeling some. Also the edges should be chamfered a little. Just the leading and trailing edge. A lot of brake pads will make noise, depending on their compound. Semi metalllic pads are notorious for this. You may need to look into some organic compound pads. Another issue, shouldn't be a lot of a problem on a bike, is semi metallic pads produce a lot of dust, which will in turn produce more noise.
Old Apr 29, 2014 | 07:55 AM
Conrice's Avatar
What kind of noise? Is it actually a squeal? Or is it a different kind of sound?
Old Apr 29, 2014 | 02:54 PM
geez's Avatar
Thanks for all the suggestions! Yeah a squeal is probably the best sound to describe it. I don't know what make the pads are, I had the servicing done, but I'll try to find out. Also I'll try filing the edges and clean up anything that might be caught in either of them. Actually just today I did some 80km on it, with lots of medium braking and downhill. At the end the noise seemed somewhat less severe than it was before..
Michaud85
Nov 3, 2018 01:43 AM
CBRf4iX
Mar 18, 2013 07:52 PM
Michaud85
Oct 4, 2010 11:07 AM
zone01racer
Jun 2, 2010 01:19 AM
djdc78
Feb 12, 2008 01:12 PM
