No spark Q ????
Old Apr 1, 2009 | 07:12 PM
RUBZERK's Avatar
Question No spark Q ????
my cousin has a 00 cbr f4.
He has no spark & was wondering if a bad stator will cause no spark ????
Old Apr 1, 2009 | 07:32 PM
justasquid's Avatar
Nope, stator has nothing to do with the spark. the bike runs off the battery, the stator just recharges the battery. Your rectifier has nothing to do with either.
Things to check. Kill switch, kickstand switch, (BAS) bank angle sensor and fuse.
Old Apr 1, 2009 | 08:55 PM
RUBZERK's Avatar
where is the BAS located on a F4 ???????
Old Apr 1, 2009 | 09:10 PM
justasquid's Avatar
It should be mounted on the headlight. Its located between the fairng stay and the headlight. Some were mounted in under the seat, but I cant remember which models those are, but Im about 95 percent sure the F4 is located on the headlight.
One thing to consider. the fuel pump wont kick on if the bank angle sensor is bad. So it that is working, then its not the bas.
Also, you can bypass the bas by jumping the two outer wires on the harness plug to see if runs.
Is there any other information that will help with diagnosis?
did it just stop running?
was there a crash or anything?
Old Apr 1, 2009 | 11:46 PM
RUBZERK's Avatar
He bought it wrecked. He got a new battery & a few new relays.
Old Apr 2, 2009 | 05:25 AM
justasquid's Avatar
Be sure the upper harness is hooked up. the one that plugs into the headlight and the gauge cluster. It will not run without it hooked up.
Old Apr 2, 2009 | 05:41 PM
RUBZERK's Avatar
dealer says there is no BAS sensor on the f4
fuel pump works
Old Apr 2, 2009 | 08:26 PM
jonld's Avatar
make sure the crank pulse sensor is plugged in. thats what reads the timing and tells it to fire.
Old Apr 3, 2009 | 01:13 AM
justasquid's Avatar
sorry about that. The BAS sensor wasnt until 2001. My mistake.
baseballkid
Oct 4, 2012 07:48 AM
cncquinn
May 21, 2011 04:55 PM
jaredaamy
Jan 1, 2009 10:51 PM
Bazman
Nov 23, 2008 01:13 AM
w4kr
Jun 11, 2007 04:44 PM
