No Spark on cl 2&3 - please help
Old Sep 2, 2018 | 04:45 PM
CBR600FA's Avatar
Default No Spark on cl 2&3 - please help
My bike (CBR600FA 2011) turns over but refuses to start - sometimes it does start but very poorly only on 1 cylinder (cl 1)
For some background: I was out for a ride when all of a sudden (about half an hour into the ride) I felt the bike exhaust note changed and the bike lost a lot of power.
Managed to ride the bike back home (about 15 miles)
I have since determined there is no spark on cl 2&3 which is controlled by the coil pack on the left side. The coil resistance was out of spec so I went ahead and ordered another coil pack and also replaced all 4 spark plugs at the same time but unfortunately the problem still remains.
I now have new coils and both primary and secondary resistance is per spec for both coil packs & brand new spark plugs.
I have established for sure (via various tests) that both coil packs and all 4 spark plugs are in full working order and the problem seems to be pulse/power coming to the coils. I get a reading of 12.xx volts on the both sides but only if I ground the negative wire to the body. the reading is all over the place if I connect the multi-meter to both wires to the coil - is this normal?
There is spark on cl1&4 and the bike used to start and run though very poorly on 2 cylinders (1&4) until today - now though the bike is still getting a spark on 1&4, only cylinder 1 is firing.
I did jet wash the bike a few days before but the bike was absolutely fine a few days after that - thinking there may be a relationship, I have since disconnected all connectors and sprayed them with contact cleaner and put them back together which has not helped.
Any help/guidance will be very much appreciated. What to test next/how? Thank you
Old Aug 28, 2019 | 09:04 PM
Sergio cbr's Avatar
New Member
Hey did you ever find out why they weren't firing?
Old Sep 6, 2019 | 04:22 AM
CBR600FA's Avatar
Yes, unfortunately it was a faulty ECU - replacing the ECU and programming new keys resolved the issue
CBR600FA
Sep 1, 2018 06:17 PM
Rhondasoulsoothinghonda
Aug 29, 2018 07:29 AM
sjona2011
Aug 17, 2013 07:24 PM
harveyjoykill
Oct 16, 2006 10:47 PM
grwilson6
May 8, 2005 01:02 AM
