No lights including dash
First step is always to check the battery voltage, and your next stop should be the fusebox. Make sure to check the dash fuses, as it looks like that's where the problem is
With collisions it's always possible that wires have been damaged, especially in the crash area. I'd remove the fairings and give them a good visual. Check for torn insulation or burn marks. Probably a good time to check for hidden crash damage too
Report back once you've done that and we'll try and narrow it down from there
pookguy88
Jul 20, 2012 07:30 PM
