low side, got no headlights
Old Oct 2, 2010 | 11:12 PM
kenshin81's Avatar
Default low side, got no headlights
not sure what the problem is. had a low side making left turn under 15 mph. no real damage that i could see besides clutch lever bent up and scratched fairings, but headlights and maybe gauge lights (not 100% sure) wont come on. cant take fairings off til tomorrow to look at it better, but any ideas what it might be? maybe a connector came loose? thanks.
Old Oct 2, 2010 | 11:32 PM
iJapanesey's Avatar
check your fuses under seat first, then connections 2nd.
Old Oct 2, 2010 | 11:36 PM
kenshin81's Avatar
forgot to put in first post, but turn and brake lights do work. will check tomorrow iJapanesey. starter switch did feel funny though.
Old Oct 3, 2010 | 12:07 AM
iJapanesey's Avatar
Yeah I think turn signals and brake lights are different fuses, so def check under your seat for that. You may have to unscrew the on/off switch to make sure things didn't get jammed when it went down. But that wouldn't have anything to do with the lights, unless it sent a short.
PS- if your gauge lights are out too, check the connector right under your lights
CosmoBob
Apr 20, 2007 02:59 PM
