low side, got no headlights
not sure what the problem is. had a low side making left turn under 15 mph. no real damage that i could see besides clutch lever bent up and scratched fairings, but headlights and maybe gauge lights (not 100% sure) wont come on. cant take fairings off til tomorrow to look at it better, but any ideas what it might be? maybe a connector came loose? thanks.
check your fuses under seat first, then connections 2nd.
forgot to put in first post, but turn and brake lights do work. will check tomorrow iJapanesey. starter switch did feel funny though.
Yeah I think turn signals and brake lights are different fuses, so def check under your seat for that. You may have to unscrew the on/off switch to make sure things didn't get jammed when it went down. But that wouldn't have anything to do with the lights, unless it sent a short.
PS- if your gauge lights are out too, check the connector right under your lights |
